Quick question - Checking oil
Engine off, and should have been off for at least 10 minutes on flat ground is my rule of thumb.
Engine on you are getting nowhere lol!
just make sure it's on the flat and switched off for (as you say) about ten minutes - from cold all the oil will be in the sump so you will get a good reading, if it's been running then leaving it for ten mins or so gives the oil chance to drain back down.
The oil will be in the engine when it's running, think about it...
Better safe than sorry though!
You should be checking it weekly.
