Quick question regarding ABS rings
  Clio 2 1.2 16v
Hi Guys, I've just had my driveshafts replaced at the front on my mk2 1.2 16v clio but now the speedometer is way out (nearly double to what i'm doing) and the abs light is on. As my car is 02 would I be right in thinking that the driveshafts that have been fitted have got 44 teeth abs rings when I need 26 teeth and is this as easy as just heating the ring and replacing with a 26 teeth ring?
  Cup In bits
Yes ring can be replaced just like that.
I had the same trouble figuring out which rings my mums car required which is also an 02 and also the rear drum size as there was a switchover point for both these things that cannot be found out other than physically looking. I had to check the amount of teeth on the rear as unfortunately both front rings had fallen off.
