QUICK wiring HELP please
  Abarth 500
im trying to feed a cable thru to the battery from inside, whats the best or easiest way to do this, ive seen where the bonnet release goes thru but that is all sealed up and cant get anythin thru, also seen the washer jet for the back but thats hard to get to. Any ieads? where does the wiring come in from the underbonnet fuses? i know the cable feeds past the washer bottle cap but cant see where it goes from there....do i neeed to take the dash off to see that? im in the middle of it now
cheers
  clio 1.8 16v
just drill a new hole mate with a 8th drill bit first then go with a cone cutter to just a bit bigger than your wire the put a grommet over the wire and feed it though make sure theres nothing behind like wires or pipes when your drilling try get a mate to help u 1 out side and 1 under the dash hope this helps
  Abarth 500
cheers...ive searched and most people say to go thru the bonnet realease, ill have to look at the again try get the rubber out, take a bottle off in the enigne to get behind and look???
  Rb 182
Try looking under the rad bottle on the pass side at the back of the engine bay.
Im sure there is a hole there
Yep thats the wiring loom harness connector block no way anything else would fit thought there.
Most people use the bonnet realease catch otherwise there not that mnay holes the fan system isn't realy an option.
  Abarth 500
wahoo got it in the bonnet release....all it needed was burt force to pull the gromit out!....sort of went back ok lol.....cheers
