Racing Blue
Car  Clio 182 RB
Does any one no where i can get a touch up pen....and a can spray of the Racing BLue???...already tried halfords! will renault do them? how much? cheers
Wilco or most Motorfactors should be able to Mix up some Paint if you give them the Paint Code
i got an aerosol from renault a few weeks back and it was £16 for the base coat and lacquer:)
halfords will mix you a can up if you give them your paint code and will be cheaper than renault . plus you can buy prep materials while your there
if i go halfords will they give me a tin of the paint??...if so if i wanted to spray the wheel diamonds...how would i do that from a tin.dont want to brush it on..it would look crap!!
yeh they can make you a tin of cellulose based paint that you will have to use through a gun . or they can mix you a aerosol can of any colour you want .
Aren't halfrauds a bit hit and miss with mixing up the paint though?
I had mine mixed up by a local paint shop for a tenner. Spot on, they were.
i want my bullets black with racing blue 2.0 16v how how i do the writing from a tin...really need a pen! any ideas thank?
Touch up pen is easiest, you can do it with a brush used for models and such but you've got to have a steady hand and some patience!
Thiiiiiink you can have them made up like that too? Have you mooched about to see if you have a paint shop in your area?
