Rad fan kicking in on cold start up?
Car  SG 200 Cup+F4R'd MK1
WWWHHHYYYYY???
Anyone know why this could be happening?
When i turn the car off it slows down and then turns off after about 30 seconds.
Thanks!
I dont have air con, its definatley the rad fan.
Forgot to mention i have a MK1 F4R conversion.
Check the coolant temp sensor is plugged in and is working correctly. When this is in open-circuit the ECM turns on the fan incase the vehicle is in an overheat situation.
Mick
Just tried a new CTS and that didn't work. There is no reading of temperature on the clocks. Tried a new relay also, no luck. Is there anything else it could be or shall I start checking out my loom?
Ta!
Ideally I need to see it i'm afraid mate... could be an ECM AC request fault (if you're running a "modified" aka de-coded F4R Sirus ECM), a bad or back feeding earth on a circuit or a simple short to earth somewhere.
Mick
