Don't think this is working. Not heard it go off in ages. Even when i did a track day in her. How do I do a check on it? It moves if i physically push it.
Which gauge do you mean? I have never noticed it coming on in heavy traffic before. I have noticed what looks like steam coming from somewhere between the passenger headlight and the radiator. Wondered if this could have something to do with it not coming on?
With an you RSTuner will be able to check that the ECU can trigger the fan properly (in the Diagnostics you can manually operate the cooling fan on high and low speed.) You can also read off the Coolant Temp Sensor output using the Live Data while the engine is running. So basically you can check the whole lot out.
Those functions aren't locked down to individual vehicles so if you can find someone who's got one already.....
