Radiator replacement - 200 Cup
Car  Clio 200 Cup
Unfortunate enough to have sprung a leak on my radiator😡
local garage are quoting me about 400 quid. This seems expensive? They are saying no one supplies the radiator apart from directly through Renault, I have seen some on eBay that are a lot cheaper, are these ok to use Or do I have to go for the official Renault part? it is a cup so has no aircon, just needs the rad.
thanks in advance
Freddie
Are you in the UK?
This is the price for a 200 CUP one directly from Renault. Use the part number from the picture to search on ebay and other places.
Obviously you will need a coolant change with TYPE D coolant from renault (https://www.ebay.co.uk/itm/5-LITRE-TYPE-D-ENGINE-COOLANT-ANTI-FREEZE-FROM-RENAULT/281610886635) 5L should be enough.
Do you plan on doing the rad change yourself ?
£400 all in isnt outrageous, it is a little expensive but the job will be 2 hours ish once the rad has been changed and the coolant changed and bled etc.
