Radio dimmer syncs with indicators and brake light??
Car  172
Ok, I have some weird issues with the clio.
1) Sometimes the fog light dims on the dash when I brake
2) When my indicators are on the dimmer on my cd player flashes in sync!
3) When I press the brake the dimmer also comes on the cd player!
Any clues? The rear clusters seem fine!
cheers.
your gonna have an earth issue someone along the line with the lights,cant specify where,youll have to trace the wiring.once you do that all your problems will disappear
My 1.2 MK2 Clio Extreme and Dynamique BOTH did this too. Upgrading the earths in the engine bay helped a lot but didn't get rid of it 100%. The standard Renault earths seem pretty crappy.
take the rear light connectors off and get a little screw driver and gently push the metal tags in the connector towards each other to make the connection tighter if that makes sense. had to do it on mine works a treat!
