Rattletastic
  RS Clio 182 Cup
Alright all? Cracking site this btw
Just a quickie...I know the clio is designed to rattle but I've got a new tinny sounding one that seems to be coming from the interior at the rear somewhere (it's a bit hard to track down as only happens when driving) and there's nothing in the boot etc.
Just wondering if anyone else has had similar and worked out the problem/fix??!! Can't be the rear window surely?
cheers
Wig
  Focus ST
I had a problem with the back parcel shelf (not that you've got a front one).
Rattles against the bott lid. The only way round is either a new (better fitting) shelf, or move the rubber stops on the shelf.
ant
  yep.
i get that one, like a tinny, metalic rattle. no idea what it is tho!
only happens at certain revs.
Addz
  Trophy, TVR Tamora
i get that, sounds like its to the left of me somewhere, my dashboard does it to :(
same rattle,it comes from the plastic on quarter panel that meets plastic to support rear shelf just at edge of back seat i put a thin bit of gortex between the two ,hey presto.:D
  182 Cup, (2nd one)
Lol, is somebody complaining about the rattles in the RSC????
Just turn up the stereo, get a Pro-Speed exhaust and put your foot down so you can't hear them!!!!!! ;)
  www.renparts.co.uk
ive got one under the drivers side tweeter in the dash. I think its from when the handsfree kit was fitted and they removed the dash top... i plan on removing it again to work out what the rattle is.... is this easy?
thanks
josh
  M140i/Orange 182
thanks
josh
removing dash is easy...just make sure you disconected the battery first!
remove silver strips, plastic panel on the steerng wheel, unscrew all screws(including 2 screws on the side of the dash), remove door seals and un pop the A-pillers and slide out job done:cool:
J
jamesy
i get a rattle from what seems to be my rear seatbelt clip when i get to x amount of revs so makes me think what's gonna rattle when the sounds go in:S
  Megane Mk4
Thats the ONLY rattle I have inside :D
( I must have a better built 182 than you lot!! :rasp: pmsl )
Although saying that, the only reason it rattles is because of the 6x9's in it :eek: .. It's bounces like it's going out of fashion!! lol
