Rattling/Knocking, new noise!
  Clio 182
Morning guys,
Had my car serviced on Fri and had discs and pads changed. Car running well but there's a new noise coming from the front off-side.
At low speeds (upto 30-40) there's an occasional rattling/knocking sound which is quite irritating.
I didn't have any suspension work done and the noise didn't exist prior to the service.
Any ideas what it could be?
Cheers,
Dan
  clio 1.4RT
possibly they havent tightened up the breaks properly..... also wheel might be loose.
you would need to jack it off the floor to see if anything is loose
  Focus ST
its a clio, they all rattle dont they ;)
might be a loose heatshield or something under the bonnet?
calipers should be as tight as they can be anyway, they just spring back into place. wheels should be checked anyway but would be a grinding noise with wheel wobble if loose.
best option would be to take off wheels and refit, check all fixings are torqued up whilst down there. Other than that, check under the hood and see if anythng has come loose/needs tightening
