RB PH-1 Hits Cadwell park
Car  B/G 182 + PH1 Track
Well it was our first time at Cadwell today.....what a circuit.
After i destroyed the Diff at croft the other week we decided to purchase a Quaife LSD, after a bit of a rush the car was all back together late last night.
Carl and Jacko drove the track car down to Cadwell early this morning whilst i drove up from Coventry (A46 WORST ROAD in the UK :dapprove:)
We met at Cadwell and did the usual briefings ect. Some how the Car only make 93DB today whereas last week it made 101DB.
Morning sessions went well, car was running nice after a few laps and a bit of practise with the LSD we were putting in some decent laps.
It pissed down over lunch.
After lunch the track took about 1 hour to dry, it was really slippy through, Hall bends and Barn due to the trees.
Ones it dried out again it was really good fun. :D We are still suffering from a bit to much understeer, so think some softer front spings may be on the cards.
Some photos will sort the rest tomorrow.
Thanks /Adrian
cant wait to see how the hybrid is round there next month.
you running mega positive camber on the fronts lol?
its running 2.3 neg camber. I have no idea why it was doing that tbh.
Lol, it always seems like I'm having a go at you two, not the case - just observant!
Bottom of the mountain, no lock applied, this is not 2.3* negative!
Shock>hub bolts loose?! Active camber :rasp:
Fox's car, 2deg negative, under similar load to some of your pics I'd have thought. Note how it doesnt look positive
id look at your top mounts but when pushing a car the wheel its leaning on to does tilt over, neggy camber is put in so that you get less lean when pushing hard, also take a look at stifening the rear to stop the front leaning so much.
how on earth do you know same load etc?
what tyres was foxy using? R888's? same road surface? same track?
if not you cannot compare. The printout doesnt lie.
carl
exactly! we use comp top mounts (already on the car when we got it) obviously not the best but they do for now with camber bolts. The coilover setup is taken from FMP with 750lb rear springs and revalved to suit. The front is still too stiff though. :)
carl
You sure you havent got worn bushes for the wishbones or similar. If they are moving under load then that will be causing the understeer. The print out may show neg camber when stationary, but this will change on the move if as said bushes etc are shagged.
Car looks nice btw
You sure you havent got worn bushes for the wishbones or similar. If they are moving under load then that will be causing the understeer. The print out may show neg camber when stationary, but this will change on the move if as said top mounts, bushes etc are shagged.
see why not post like this whiteley instead of posting comments showing your ignorance?
thanks mate, looking at getting some poly bushes for the whole car so possibly i think this could be the next move :)
carl
Lovely car but it definitely looks like something weird is going on with the front wheels under load!
More vids please! Love the sound of this one. :D
It will not be at FCS, too many keyboard tuners on here ;-)*
*real reason is that I'm going to croft to watch BTCC instead
I'll give you a shout Riad when we are going to do oulton park, happy to take passengers out :-)
Carl
Carl
Sounds good to me!
:D
Wasnt too long ago you were part of that group Barron, lighten up and take the criticism, posting on a public forum is not always going to get you the answers you want to hear, with positive comments come negative ones, your car may have negative at a standstill but theres definately something not right when running, people are letting you know this so you can maybe have a look at whats wrong, learn to accept peoples comments, your car looks great but dont you want it to run great as well.
Its cool :-) it will be sorted and back on track asap :-)
Carl
Mind giving me a shout if you're at Oulton as well please Carl? For the photography and to meet up as much as anything lol. Love this car.
i do have some video jacko took at the mountain complex but can not find the lead for the camera, will take it home for carl to sort on friday.
I saw that too guy, were you on track? Or just taking photos?
Carl
