Rear brake pad carrier
Car  Clio 172
Fitted new rear discs went to refit brake pad carrier and the bolt holes don't line up. The piston is wind right in any ideas?
It's been a while since I've done rear brakes on a Clio so I can't think why the holes wouldn't line up.
How far out are they?
Is the little lug on the pad fitting into the recess on the caliper? If not it could cause enough of a problem to stop things fitting properly
