Rear disc's and pads?
  FF Clio 182
For a 182, Are there any good after market disc's/pads out there or is it best to just stick with genuine parts? Secondly, how easy are rear disc's to fit? I believe the genuine ones come with the bearings already pressed so is it just a case of sliding them on ?
I'd just stick with genuine tbh mate. That's what I use on mine, and yes the rear bearings are already in them so pretty simple to fit.
  FF Clio 182
Thanks mate just didn't want to get a set start ripping it apart then run into a problem :) That will be a Saturday morning job then :)
  Cup In bits
I would get the rear disk spacers as a precautionary as I removed a set of disks last week that didnt have them fitted which delayed me 4 days when I had to order from Renault, they are only £7 a side iirc.
Don't bother with genuine, see G172 on here who will supply Brembo disks and pads which will be £101 delivered iirc, Brembo use similar high quality bearings if not the same as the oem Renault disks.
  iceberg phase 2 172
yeah be best off getting some the rear disc spacers just incase , i changed mine on friday and the spacers had collapsed , im still waiting for renault to get them in for me :( tomorrow hopefully
Unless you're tracking it alot, don't see the point in DS2500's, bit overkill imo. (And the fact they're illegal, but there's probably more chance of winning the lottery than getting caught).
Just my 2p though.
  FF Clio 182
Just my 2p though.
Yh old bill pull you over and check your brake pads lol what about braided brake hoses are they worth the upgrade ?
