rear discs for a 172
Car  clio 172
need some rear discs for my 03 plate 172 i have needed some for a while but looked today and one has broke in half...any places to get some at a good price as money is a bit tight as i need engine mount and cam belt is due for a change
cheers
cheers
your disc has broken in half?! do you not meen the brake pad?
As good as the exact same discs that Renault will give you and charge you 3 times the price
Make sure you get the discs with bearings and abs rings already on them. Its not safe to drive with them cracked!!
Also, mind and make sure the thrush washer stays or goes back on the same way it came off, as i found out the hardway when it went on the wrong way and broke into hunners of wee bits and i had to order one from the factory in France, 3 days that took...
