Rear Fog Light Indicator
Car  02 Silver DCiExtreme
So every time I use brakes and the brake light illumantes, the rear fog light indicator (on the dashboard) also illuminates. As far as I am aware, the actual rear fog lights don't actually illuminate. Also, whenever I use the indicators or hazard lights, the rear fog light indicator on the dashboard also illumantes every time the indicator bulbs are on. this has been happening now for quite some time and was just wondering if anybody has any solutions to this problem? Or even if anybody else has had this problem?
Many thanks,
Gavin
I had this, turned out to be rusty connectors on the rear lamps took then off cleaned them and put some WD40 on them and they been fine ever since
Yep as stated above you have a bad connection on 1 or both the rear light connections easily fixable with a small file
Same as Mack, my connections were really bad. I just used a small wire brush then some sandpaper. Good as new :)
