mine does this too... but only the dash light. the fog light itsself doesnt come on or flas when the indicators are on. Also, that only happens when i indicate right.
Check the connections to the rear light on the right hand side. Then what I've said in the post above should suffice.
Check them again, make sure there is no play in the connection.Check the connections to the rear light on the right hand side. Then what I've said in the post above should suffice.
i checked the connections and they looked fine to me... would u suggest just spraying a little wd40 in the connections?
Check them again, make sure there is no play in the connection.i checked the connections and they looked fine to me... would u suggest just spraying a little wd40 in the connections?
no play?
it all looks normall under the bulbs... jus looks like it could benefit from a little wd40 tbh lol
no play?
Both sides????
Just get a nail file or sandpaper and run it over each one of the prong (connections), then see if it happens.
Both sides????
Ahh okay mate, i will do... then a little wd40?
