Rear Hub Spacers
Car  Clio 172
Hi,
I am looking for some spacers for the rear of my 172 at the mo and have stumbled across some of the square spacers that fit behind the brake discs.
What are peoples experiences with these???
I believe those are the only kind available for 1*2s. They fit between the stub axle and the rear beam, wont put any excess stress on the bearings either.
Thank mate. Im just thinking that the square behind disc ones will place the hub under less load so may be better. Dont have to worry about the wheel coming off either hahaha.
I have found a set of 15mm ones with new bolts for the hub for £39.
When I'm back in a mk2 I'll be getting the square type.
Like u say, less strain on the bearing, cheaper and can add camber.
