Rear light help
Car  RIP MK2 PH1/1.4 16v Polo
can i plug in mk2 ph2 rear lights on my mk2 ph1 and they will work or do i need to do anything to them?
thanks
It can be done, however you will need to change the wiring. IIRC FuBar has very good guide on the wiring on his website.
you can change just the plastic lights over (keep the same bulb holders)
will fit with some small modification,
however on the ph2 the swapped the brake/sidelight and foglight over,
so the lights will light up in the wrong cluster, still red though,
other option is to buy the ph2 bulb holders, and get a cliosport membership so you can see what wires you have to change in the guides section :D
