Rear lights problem!
Hi,just joined the forum so I thought I'd start with an easy problem!!
Brake lights and fog lights have decided to stop working.Checked fuses and bulbs, ok. The earth point for the back cluster is not corroded and the reverse and indicator lights work ok. The rear high level brake light is working fine.When you press the fog light switch the buzzer goes of when the door is opened so I presume the switch is working.
Any thoughts anyone,
cheers Andy
