rear seat belt plugs - fitting resistors
haimsey
  ph2 172
I stripped the rear of my car, where are the plugs that the resistors need to be pushed into?
I can seem to find them, took rear seats and belts out a couple month ago and cant remember unplugging any plugs from them
Just want to know where theyll likely be in the car
haimsey
  ph2 172
Maybe you could help clear up where they go, as there are lots of search results that mention it but nothing completely final
haimsey
  ph2 172
They've only come on since removing the rear seats though. That is the confusing thing
Dicky Belly
  Whichever has fuel
There are no wires, so it can't be that.
You must have disturbed the wires under the front seats whilst moving the chairs forward and back.
Dicky Belly
  Whichever has fuel
Right, will check all the connectors in the front in day light
Turn the ignition to position two, look at the lights on the dash and wiggle the wires and connections (with force) and if the airbag light goes out, you've found your offending wire/connections.
haimsey
  ph2 172
Now I know for definite there's nothing in the rear that can be causing it hopefully get it sorted
