Rear Side Door Will Not Open - Help!!!
AS title Says. One of the Back doors on the Missues Renault Clio will not open. Its Central Locking the Button just stays in the locked position. Cant even pull the Button (Door Pin) up to open it. Any ideas.
take the door card off and have a look, probably something getting stuck!
you can take the panel off but you will have to take the rear bench out proberly something jammed or worse case lock failed.
