Rear spacer on drums help.
First off I've already tried searching, found a few things but not exactly what I'm looking for.
question is, currently running a 1.4 with rear drums. Looking to space them by 15mm.
Do I need a specific set of spacers for the rear? Are they different in anyway? I have 25mm delta mics on the front. Just wondering whether it's the same setup?
Thread moved to the correct section by jesus. Please post in the the appropriate area next time.
Some bolt-to-hub spacers will do the trick fine, same bore etc as the front.
but you can get shims that sit behind the hub for the back, so it wont but any extra strain on your bearings
