Rear suspension damper on clio 182
  clio sport 182
I have a 6 year old 182 and i've notice the driver side rear damper is leaking quite bad, is this a common problem on 182's?. It was hit a couple years back when its was parked up and i have nothing but problems with that side of the car. And does anyone know a rough cost renault charge for part and fitting? been trying to ring them all day just kept putting me on hold!!!!!!!!!!!!!:mad:
  clio sport 182
cheers, i wish i could but i dont have the tools!, plus the things need a service i'll get them to do the whole lot in one visit. any ideas on labour charge?
  Mustang, S13, AX GT
pm joshydee at cliospares, I got a shock from him for about £30 delivered. Like Beef-Mc said it took about 10 minutes to swap them over. all you need is a socket set and a breaker bar ;)
If it's renault I think it's around the £80 an hour mark in labour.
Where are you based, plenty of RS specialists who could save you a fair wedge.
  clio sport 182
i'm in the sussex area not to far from brighton! as for doing it myself how's easy is easy i'm not that mechanically minded!
  Mustang, S13, AX GT
1 nut, 1 bolt off and its off, same again to put it back on. If I can do it any-one can haha.
ripp
  182 FFAT
yes it's a common thing for them to go soon. mine lasted 45k and were also leaking badly.
but as said above easy to fit
Hardest bit is cracking the bolts holding the shock to the hub, if the bolts haven't been undone anytime recently, they can be an arse to undo.
  Clio 172 CUP
Hardest bit is cracking the nut holding the shock to the hub, if the nuts haven't been undone anytime recently, they can be an arse to undo.
no word of a lie... took an hour for me to get the driver side bolt off... get a can of WD40! once that was off, 10 min job if that - make sure you take the wheel off first as they are heavier than you'd think ;)
  Golf GTD Mk7
Breaker bars are your friends ;)
