Clio 172
Hi all
So I'm looking at sorting the rear toe & camber settings on my 182 track car.
I have got a 10min shim to fit to the rear left side and and 20min shim to fit to the rear right side to get 10min toe-in left side & 6min toe-in right side.
However, if you also look at then camber it is nearly 2' on left side and jus under 1.5' in right side. So what I'm thinking is getting the 30min shim to fit the right side which will even out the camber. If I fit the 20min shim to the right side for toe And also the 30min shim for the camber, will these be okay to do?
