Hi
The past winter has not been so kind to the underside the Clio 182. Underseal has been damaged or hardened and split, allowing water in and this has caused areas of corrosion around the rear parts (i.e. boot floor and structures either side). The rear heat-shield is also corroded from bimetallic corrosion around the exhaust mounts and it already has the larger washers installed by the previous owner for the other fixing points.
For those who like to keep the body shell in good condition, how do you remove the factory under seal and what have you applied as a replacement coating?
For those who have had to replace the heat shields, what products have you used? Do those who race these have a better alternative perhaps?
Thanks!
Thanks!
