Rear window washer jets ??
No idea where to post this so here it is.
Smoothing the boot next week. So at the moment I’m removing Lock/Jet Washer/Wiper motor.
Just wondering how will I stop the washer jet spraying all in my boot? I have removed the tubing up to the rear seat... Where else can I remove so it doesn’t spray??
Many thanks :)
Remove the pump stick some sealant on the hole on the tank will save weight as well. Plus since the front and rear are the same you can use it if the other one ever fails.
You won't miss it its on the tank.
You can just unplug the wiring and the piping if you want to.
