recaro tendline seats
  Recaro'd 182
Just fitted the recaro trendline seats to my car. Are the seats supose to tilt forward and slide forward like the standard 182 seats when the handle is pulled to get in the back seats os just tilt forward.
I am also unsure where the cable wire goes. Does it connect to the same place as on the standard seats subframes?
  200 Gordini
They're quite stiff. They tilt forward then slide
If you have a FF then you need airbag resistors but ive still not got mine and im rolling with service and airbag light ;)
My passenger pretensioner is a mystery too!!
  Bumder With A Buffer
If you want some resistors let me know...will only charge you postage (28p or whatever it is!)
  Recaro'd 182
the seats are in and fitted, just need to sort the slide forward bit out. the cable needs re-attaching i think, see number 5 on drawing. Where does that bit go.
  200 Gordini
I had the seat out earlier too! I could of got pictures.
iirc it goes near the back of the seat
  V6 255, 172's, JCW,
Are both seats not working correctly.. or just the one.? Is it without doubt the cable thats not connected..?
