just want better idling from cold and wondered if it would benefit the car i know it wont give more power
It will ! best mod you can do on a 1*2 imo drives so much nicer also has daignotic facilites too look on here in for sales they come up for about 110-150 but sell REAL fast !
Theiy're jus plug n play m8. Buy 1 an put it in it obd port
they do pops n bangs innit![]()
Unless you've modified it a lot, just get the RSTuner (have a search on here, covered more times than you can count) map, will cost you much less than a live map.
It will improve low end, slightly raise the rev limit, improve idle at first start and other things. :].
100% the best mod you can do for the cost (around £50-£100 depending how you do it).
The standard map from renault is atrocious upto 5K rpm, so there are genuine gains to be had by correcting the fuelling upto that point.
It also tidies up the idle, and increases the rev limiter slightly.
