Cheers, shame there isn't a CS remapper, might pay to invest in the equipmentI would always go with a company with a good reputation obviously this could be more expensive but you hear so many stories about bad remaps buying cheap seems to be a big no no
Celtic tuning have always supplied me withhold maps and can visit your home.
Just watch the torque doesn't kill the clutch, and have you had the swirl flaps removed from the inlet?
Rs Tuning
I would be very dubious of a £100 'remap'
I would go to a proper tuner, who knows what they are doing.... RStuning in Leeds for me.
I do go past Leeds now and then, any idea what they charge?
Avoid cheap remaps. They'll always cause problems being a generic map.
Whats a swirl flap? Excuse my ignorance.. Where are Celtic tuning based?
Googled Swirl flaps, Ive never removed them and wouldn't like to start stripping stuff to check.. When its next serviced ill ask my local mechanic to check it out..
Great advice guys, Ill take it all on board.. Think I need to find someone locally who can help with my mods... Not sure what to do but thought remap is a good start..
Remap was a good startthey struggle with turbo failure , so make sure all that is okay first anything untoward don't start ! Same again with clutch, it may still slip the clutch but that's a risk you'll have to take!
As for the inlet flats , there are valves that are inside the inlet manifold that open up more under heavy acceleration , I think they are to swirl the inlet air for better combustion ! They also have a tendency to fall inside the engine and go ca-boomy :/ a lot of people remove them to stop any further issues ! Hope this helps a little
Dean
Chris at efi parts is not very far from you at all. my car is going there to be mapped at some point and its 250 miles away.
