remooving rear wiper
Car  1.2 16v
right, its well complicated, ive taken the real boot lining off and am faced with some sort of tripod motor.
i have taken the 2 visible bolts out but it aint mooving, im tempted to hacksam the little bugger:)
anyone else done this? please help, cheers
I've got a mk1 but I still hacksawed mine off from the outside. Impact should work though. Use some penetrating oil then wack the f**cker, make sure you don't dent the tailgate though. OR
Buy a haynes manual.
Ali
yep, mk2 ph2 dynamique, wanted to know how to get the wiper mechanism off and the wiper out so i can colour the surround, any help welcome, thanks
i have. so you've taken the wiper arm off? and your left with the stubby bit. Theres about 3 10mm bolts, but i cant remember what else. I'll check at work tomorrow for you.
ok mate, no i havnt taken the wiper arm off, i have taken the outside bolt off and 2 bolts off of the inside and now im stuck so could you just give me a step by step fella? cheers
pm s garbett on here, i knwo he did his and had some trouble with it but managed to get it off...
really just saw it off? im thinking of doing it because i cant get the b*****d screws off!!!
If you saw it off you'll need a new motor. You'll need a 3 arm puller to get the arm off, DON'T HIT IT! You'll break the glass.
