Please forgive me for what im planning to do, ill be totaly honnest, i dont have a clio, or any renault car, i have a van im converting into a motorhome, and got a new mp3 player stereo for xmas that ill be fitting, in my van the stereo is very low down, but the new stereo has a single wire input for a remote control (its a panasonic stereo btw)
so i went down the scrapper and found the best looking stalk remote control for a stereo.. turned out to be from a clio
i think it was a post 2000 model clio, rounded body, but the actual car i got the stalk from had been fitted with an aftermarket stereo, and to buy the adaptor box i need to make the clios remote work with my panasonic stereo, i need to know the make of stereo fitted origionaly to the car i got the remote from.
The remote wasnt connected in the car i got it from, the aiwa stereo in it couldent take the remote i guess,
I chose that car to get the remote from as it was the only clio which didnt have the remote display, and id noticed the ones with the remote display, the stalk connector plugged into the remote display, and then goes to the head unit via the 4 wire cable with the yella plug, so im thinking that the adaptor would use the yella plug from the remote display to work??
Anyway, i noticed that lagunas also have the same remote, and clios and kangoos etc, i assume they are all the same, except the plug on the end of the lead?
The plug for the remote i got was the same type as fitted to pug 306s, i.e its an iso connector with 2 extra pins, only 6 of them are connected,
i got a plug from another clio, no stereo in it so i couldent get the model number, and that one had a black flat inline connector, about 15 pins, again 6 of them connected.
then today i got a plug from the remote control stalk from a clio with the remote display in it.. this ones a flat one again, 15 pins but is a red connector with location moldings to ensure it plugs in one way round,
So, now i have a remote stalk from a clio.. 2000 on model im certian, and havent got a clue which model stereo i need to say i had to get the correct remote stalk adaptor, theres a choice of 3 adaptors, but without knowing which stereo the plug i should use went into, i cant order it.
ive put the photos of the first 2 plugs i got on my site,
http://www.kampenwagen.co.uk/stereo%20remote.htmhttp://www.kampenwagen.co.uk/stereo%20remote.htm
Can someone tell me which stereo would have had which plug for the remote used?? im thinking the white iso like connector is the one id use, (i have no problems soldering the correct plug onto the cable) but did that plug go into the back of the blaupunkt stereo, or the VDO unit without the remote display?
or another stero renault fitted in the 2000 model year?
one last thing, dont suppose someone can tell me what the bottom button on the remote does? also the thumb wheel? it seems to be about 6 switch contacts inside not a scrolling wheel? whats that do on the origional clio readios?
