Remove Resonator Box
  Clio 1.4 16V
Any idea what size pipe you used on the end of the air box as its a strange shape? If you could post a pic that would be great
Djw John
Scotland - South
I pikied it up as it was just a winter car! So it had a bit of a gap, still it gave it a bit more of an induction noise!
  ph2 172
When you remove that resonator box you get lots of induction noise, but i found just removing it felt abit like a loss of power, probably due to hot air being sucked in if there was actually a loss could be placebo. So I bought a K&N 57i gen2 and its great :)
You could also remove the air box attached to the throttle body and build yourself an induction pipe from the throttle body using silicone hose and piping with a filter on the end.
This is mine
