Removing A Pillar Covers
Car  Racing Blue 182
Anyone know whats the best way to fit these? And how to get around the alarm sensors?
I have had a search and all the other threads just say that they don't have alarm sensors, or just cut the old covers around the sensor cables. But if I did that, how would you put the new ones on without cutting them too?
Also, do you have to take the whole dashboard off to get to them?
(Sorry noob!!!!) Any advice would greatly appreciated!
Luke
Open the door on the side you want to take off, pull the rubber door seal away from the A pillar, get your fingers in the gap and pull at it towards the inside of the car till it clicks out. At the top there is a tab that goes into a hole, you need to push that towards the windscreen and pull the trim away from the pillar at the same time.
Once the trim is off, you just unscrew the alarm sensor from the trim.
Brilliant. Thanks mate. Do you need to take the dash off at all? Coz they seem to go down behind the dash?
