removing anti roll bar
Car  clio sport 172 cup
anybody know how easly it is to remove the anti roll bar on a clio sport 172 cup?? is it just unbolt brakets and pull it out or do you have to drop subframe?? cheers
Just had a look, looks like you can just take off the 2 plates on the subframe, then undo the 4 like strap/Plates that hold the ARB on and you should be able to drop it out.
Gotta stick my powerflex bushes on at some point... so I'll let you know!
Two inner brackets, and two outer brackets (to the wishbone). That leaves the ARB loose, but you need to undo the gear link bar and the rear subframe-to-chassis plates to drop it out fully
