Removing Back Seats
Car  White Sti Hatch
Right im bored have the house to my self over the weekend so means i can get in the drive....Sooooo
Whats holding in the rear bench and how hard is it to get out ! ? :rasp:
I'm guessing the mk2 and 3 are pretty similar so..
There's the metal bit going across the back of the seats (for babyseats etc), take that out. You can use a (iirc) 17mm spanner or torx bit. There's 2 bolts I think, and they can be a bit a c**t to get out, so you'll prob need an extension (I used my jack handle, take the grip off and use that end if necessary).
After that there's 2 more torx bolts in the middle of the seat (where they split), undo these and then you should be able to pull the seat out. There's some 'pins' on each end of the seat, just guide them through the holes near the door cards.
That probably made no sense whatsoever, but you'll know what I mean when you start doing it!
Even if the mk2 and 3 are different, its usually a piece of piss anyway!
The youth of today, I dunno.
If I had the place to myself over the weekend, there would be one hell of a debauched party organised, not removal of rear seats. ;)
The seats are coming out in the morning i havent told you about my afternoon/night plans ! :rasp:
Nope as it wont have ne rear springs once im back from Arbroath so itll be going no where part from on stands !
sounds good. :D take it ul never be able to get in ur drive ever again after this? hehe
