removing clio badge
WARNING - FOR THOSE WHO WISH TO REMOVE THEIR CLIO BADGES FROM A 2002 MODEL CLIO
whilst washing my car this morning (2am) i noticed that my Clio badge was slightly loose, so thought it would be the perfect opportunity to remove it making the rear end look a lot tidier
what a stupid idea that was it turns out the badge is not only glued on but it is also clipped onto the bodywork with two clips at either side of the badge, i have had to replace the bagde temporarily until i can get some adhesive to stick it back on
lol i found that out just before id taken it fully off. Not all of them are clipped in though a guide i printed of with a 2002 model was simply stuck on.
mine was glued on, as well as having clips, if you heat the badge up and slide a credit card down the C of Clio it should catch on the left hand side right in the middle where the clip is
