Removing Door Handle
Car  1.6 16v
Hi,
How do you remove the door handle?
I have taken the door card off and can see the mechanism from behind the door handle, and i was just wondering how can i take the handle off the car, so i can swap with a colour coded one??
Cheers Steve
slightly off topic mate but are you selling your old ones????
yes mate, i want to colour code mine, but i dont want to leave my car without handles for a few days while i paint them
Sorry mate, i am putting my 1.2 back to standard so need them. Then my colour coded ones are going on my new motor.
Steve
no probs mate, just thought i'd ask, c**t to get a set without being robbed!!!
Once the door card is off they're held on by 2 x 10mm bolts
There is a metal rod that operates the linkage that just pushes off
Once you've removed the 2 bolts if you hold the handle in the open position the handles slides out easier
its worth marking the metal rod at the height its currently at. Makes re-fitting easier with less guess work
Cheers Pal! Knew you would know. I will have ago.
Steve
