removing handbrake cable help!
cal
  ph2 172
Changing both handbrake cables on my 172, struggling to remove old cables from calipers.
They are really seized in place.
Am i just really weak?! or is there an easier technique to pull the cable from the caliper?
cheers
cal
  ph2 172
yeah disconnected cable from adjuster so its completely slack. should it just pull out of where it first meets caliper? its the cable surround part that seems to be seized where it slots in, not actual cable(this i have removed from caliper!)
hammer/suitable drift (screwdriver?). they can take some shifting, had the same bother before
i think it's because the caliper is alloy and will have reacted with the steel/whatever-it-is of the ferrule on the end of the outer cable
ed. need to be careful not to damage the caliper, as alloy's not tough
cal
  ph2 172
cheers fred, i'l give it a go after work.
i came to you for a service last saturday (black 172) can you remember front wheel was too far back in arch? Can't remember what you said would be bent? front arm?
