Removing headlights and front wing??? help
  A blue one
hi everyone,
got to do a little work on a friends clio, needs a new nearside headlight and near side front wing, cant anyone give me a quick guide on how to remove these parts at all?? would be greatly appreciated.
thanks in advance.
  182, 6r GTi
easy bud.
front bumper off 2 10mm bolts under the car 2 10mm bolts on either side of the bumper were the wing meets the bumper 1 plastig skrews holding the grill on pull the bunper away and undo the fogs.
to remove the headlight there are 3 bolts. 2 along the botom 1 on top, the light will then slide out,
to remove the wing take the arch liner out. 2 bolts that hold it to the sill a couple in the gap between the door and front wing 1 bolt under the scuttle panel that runs along the botom of the window then a couple more where the bonnet meets the wing. that should be all of them, ow and disconnect the indicator.
hope i havent confused you
steve
