Removing passenger seat? (Wiring)
Car  Renault Clio Mk2
So I know I just need to Jack it up and remove the 4 bolts, but what about the wire? I dont think I've got seat air bags because it doesn't state air bag on the side nearest door, so can I just remove the wire underneath and take the seat and runners out? Going to collect some tonight so may as well take it out now for more space! Cheers
If you're just replacing the seats there's no need to alter the wiring. Just disconnect. If you're ditching the seat permanently I'm sure there's a common resistor trick that will work just like if you replace the stock steering wheel.
