Removing pedal arm from pedal unit.
Si
  RS Clio 172
Hi,
I've recently replaced the throttle pedal unit on my car in an attempt to cure the fault i've been getting with the throttle (it seems to have worked :D)
anyway... the pedal unit I've replaced it with doesn't have the metal trim that the RS models have. I was just wondering if it is possible to remove the arm with the pedal trim on it and switch this part between the old and new units I have?
Thanks in advance.
