Removing pedal box
Car  182 track, Mk7 ST
How easy is it to remove the pedal box on a 182?
I'm guessing the mater cylinder etc comes with it too? With that in mind is it a job to do when the engines out or remove from the inside?
Any help would be much appreciated please peeps as I'm going to attack this later or tomorrow.
Cheers,
Grant
If it's anything like my car, which is likely, the brake pedal and clutch pedal drop out with removing the pivot bolt, the throttle just unbolts off, and the master cylinder along with brake and clutch pedal braket unbolts from the inside and tips taken out through the engine bay
