yep, there is a way. i have had mine off. replaced the awfull gold one for a crrome one. its pretty tricky and you need to be carefull. open your boot, take the plastic casing off thats inside your boot. you can reach some screws, they will take off the boot release late that has the badge attatched. once you have that off gently tap the badge out with a hammer. when re-fitting you might need a drop of superglue to ensure it fixed 100% shouldnt need it tho if your carefull.
hope that made sense
