Removing the rear wipinder
Car  BMW E92/Audi S3
Help.. ive snapped my rear wiper off in the process of trying to take it off. I want the back end smoothed off. I tried to unbolt the two bolts but they span and span and spannnnn.. ive also tried a search on here, no luck. can anybody help?
you need to put your fingers round the back of the bolts to stop it from turning while you loosen the nuts. use a bearing press or suchlike to get the wiper off the splines. they make wiper removal tools but they are shite and usually snap
i smoothed over my rear wiper in snapping the blade off aswell!
Was a pretty simple thing to do once i got the wiper motor out, i just used some 2 part metal glue to glue some metal over the whole, a bit of filler, bit of paint and now shes sorted! just need to be wet flatted then you will never know the difference!
just make sure you block the pipe off, because im sure you dont want your boot getting all wet in you accidently flicking your rear washer!
Heres a pic of mine! good luck doing yours http://www.bebo.com/PhotoAlbumBig.jsp?MemberId=224952153&PhotoAlbumId=5851614646&PhotoId=6114827565
Next thing on the list.... smooth filler cap and put that in the boot!
