Removing wipers.
Car  850 T5. mmmm Turbo!
I need to get the plastic panel off between my window and bonnet.
how do i get the wipers off to allow me to do this????
See the domed black plastic things at the end of the wipers (where the wiper arms meet the car) pull those, the nuts are underneath them.
Bump. Theres only one nut and it keeps on spinning.. now im left with this due to snapping it..
Get the plastic caps off, and there is one hexagon holding the wiper.
The wiperarms are fitted on the spline conus axel.
Undo the hexagon till the top of the tread, so the top of the axel and the nut are at the same level. Use a alligator wrench ontop of the nut/axel and underneath the wiperarm. Use this and try wiggling it off.
Doing mine I damaged a little on the underside of the wiperarm, can't be seen when fitted.
BTW renault dealer uses a tool for this.
