Renault badge
Car  Clio 1.2 Dynamique
Hi,
does any one know how to remove the renault badge that is around the boot popper?
you have to take the inside trim off from inside the boot. then you should be able to see the lock mechanism which i thin you have to take out. or the other way i think is to pop it off with a screw driver from the outside then glue it back on afterwards!
