Renault brake fluid
Does anyone know the boiling points of OEM RENAULT dot 4 fluid?
I couldn't tell you the maximum boiling point however the minimum dot 4 boil is 155°C before it needs changing or every 2 years. Hope this helps.
Cheers guys, in all the years I’ve been using it I’ve never peeled back the label on the tub, it’s 165 degrees wet... I’m now using Castrol SRF racing fluid which is considerably better [emoji23][emoji23][emoji23]
