Hi all,
new here but kinda don't really want to go to a Renault dealer until I win the lottery. I have a Renault clio 1.5 DCi Billabong and having starting problems. I will put as much detail as I can.
The issue first started a few months back. When I turn the key in the ignition,(only normally happens when engine is cold), the red top centre light which normally flashes when the immobiliser is on stays on steady and the glow plugs light doesn't light. If I then try to turn the car over, it will very occasionally turn over a little but mostly doesn't do anything. I have tried turning off completely and then back on and get the same symptoms. In my effort to diagnose it, I have found that if the light(immobiliser) is steady on and there has been no glow plug light, if I leave the ignition on for a few mins then turn off then back on, invariable this seems to sort the problem with the red light going out and the glow plug light coming on for a few seconds. I have also tried the spare key and this gives the same symptoms. Once started, the car is fine and seems to start ok when warm also.
It doesn't seem to be any better or worse through the particularly cold spell (-10) to now (+10). I have also removed and cleaned all the relays and swapped them round where possible. Now at a dead end. Anyone heard of or come across this issue. Any help would be gratefully received.
Thanks in advance
AliG :S
Thanks in advance
AliG :S
