Renault Clio 2008 (how to open console)
Car  clio 2008
Hello !
I wanna know how to open renault clio 2008 console
This one .
Thanks a lot!
put four thin screwdrivers in all four holes in the each corners, pull the upper and lower screwdrivers towards eachother (grip both screwdrivers on each side in one hand) and then just pull it out!
Seeing as you're doing it, and from what it looks like you have the same model as me, are you having trouble with you're real speakers not working? if you're doing an install then any tips you could give me? because im thinking of replacing all the speakers and adding a sub, 2 amps and head unit and it's going to be a bit of a learning curve!
