One screw out the plastic planel on the inside of boot and that will then pop off.you will then see Three nuts you need to unscrew. Then the plastic cover on the outside should come off. Then u can get to the diamond u will need to glue it back in
Take plastic trim off of the inside of the boot. Have a look / feel and you will see 2 pins beind the badge. Push these outwards and the badge should pop off.
If your gona spray the badge a dark colour, spray the boot button the same colour as your paint work or else the badge and button will just look like a square
